blancobbob Posted March 27, 2022 Share Posted March 27, 2022 I cannot get a patio slab to display. I have the active layers on but still does not display. Also, tried moving the slab to the front but no luck Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 27, 2022 Share Posted March 27, 2022 Just a guess but maybe the slab is below the terrain? Link to comment Share on other sites More sharing options...
blancobbob Posted March 28, 2022 Author Share Posted March 28, 2022 3 D Elevations - One other patio slab shows in elevation. Thanks for your help Link to comment Share on other sites More sharing options...
Chopsaw Posted March 28, 2022 Share Posted March 28, 2022 12 minutes ago, blancobbob said: 3 D Elevations - One other patio slab shows in elevation. Thanks for your help Use ALDO to determine what layer it is on in the view that it will display and then make sure that layer is on in the view where it is not displayed. If that does not work you may need to post the plan file. It could be a Material or Draw Order issue but there is not enough information to know. Link to comment Share on other sites More sharing options...
