BryanXG Posted March 18, 2022 Share Posted March 18, 2022 When you place a cabinet as a blind corner, CA automatically adjusts the filler and door size for the exposed portion of the cabinet. The filler is 2" wide... we typically work with 3" fillers to make sure there is clearance on the adjoining cabinet hardware. How can this default be changed?, as having to add a vertical blank each time is getting old. Thank you for any suggestions. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 18, 2022 Share Posted March 18, 2022 If you're trying to model cabinets more correctly (as opposed to just making it super fast to throw in place holders), then I suggest going into your General Cabinet Defaults and turning off Create Automatic Fillers. Just place those fillers manually. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 18, 2022 Share Posted March 18, 2022 6 hours ago, Alaskan_Son said: If you're trying to model cabinets more correctly (as opposed to just making it super fast to throw in place holders), then I suggest going into your General Cabinet Defaults and turning off Create Automatic Fillers. Just place those fillers manually. This is what I done for years now, and have built up a library of different inside corner Fillers, Standard Fillers and End Panels etc, mainly because Chief's dimensions won't find Auto Fillers and "Normal Cabinets will "bump" into them and stop. M. Link to comment Share on other sites More sharing options...
