Ryan_McAllen Posted March 9, 2022 Share Posted March 9, 2022 Hey folks, I've recently made the upgrade to x13 and have been enjoying the increased speed and functionality of the realtime Ray-tracing. The only issue I'm running into is that I cannot see items like plants when they are outside the windows. If I open the door, or I change the material to a general material and make it transparent I can see through, but it also looks less realistic when I do. I'm wondering what I might be doing wrong or if there is a setting with plants I can change that lets me see them because I as per the photo I have attached you can still see most objects outside the window such as the pool and other building in the design. On the left is the view through the window, on the right is cut through the glass showing what is actually out there. Can anyone help me out and point a fella in the right direction? Link to comment Share on other sites More sharing options...
Kbird1 Posted March 9, 2022 Share Posted March 9, 2022 It would be like playing 20 questions trying to diagnose from a single image, it's better that you upload a small test plan ( 25mb max) done from the default residential Template , this will also tell you if it is a fault in your template perhaps too. M. Link to comment Share on other sites More sharing options...
Ryan_McAllen Posted March 9, 2022 Author Share Posted March 9, 2022 Hey Kbird1, Thank you for your time and patience. I've attached a sample file and a camera shot saved for further reference in here as well. I seem to be able to view the terrain perimeter and whatever backdrop I've chosen in the camera view, as well as structures but for some reason plants like trees just don't appear when you look through a window, and don't reflect as well. I'm assuming it's got something to do with refraction in ray trace views because if you change all the glass to general materials and make them transparent you can see through, it just comes out looking a bit flat and seems like an odd solution to the problem. Thank you again. 1326352966_SamplePlan1.plan Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 9, 2022 Share Posted March 9, 2022 1 hour ago, Ryan_McAllen said: , it just comes out looking a bit flat and seems like an odd solution to the problem. Turn off refraction in rendering techniques or use 3d trees.@solverOP is referring to RTRT Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted March 9, 2022 Solution Share Posted March 9, 2022 1 hour ago, Ryan_McAllen said: Hey Kbird1, Thank you for your time and patience. I've attached a sample file and a camera shot saved for further reference in here as well. Hi, your sample plan isn't really per how Chief would work as technically you are standing outside looking at a single wall...... which for a 3D lighting Engine is a whole different ballgame...... so normally I'd build build a 20'x30' house with roof and monoslab foundation and add some lighting (cans) and more Windows for a true to life representation........ As Rene pointed out use 3D Trees not Tree Images from the Library. Turning Off Refraction in RTRT will take way the glass Reflections so you can see through to the vegetation...... Also if using RTRT make sure you let it run enough Samples so that the Glass isn't pixelated too ( perhaps 2500 is where i usually Cap my samples ) *** I see the new Forum file size Limit is 14mb now..... so I can't repost the file with the 20x30 house. Mick. Link to comment Share on other sites More sharing options...
Ryan_McAllen Posted March 10, 2022 Author Share Posted March 10, 2022 I'll give this a shot. Guess I better find some 3D trees. Thank you for your time and assistance. This is very much appreciated! Link to comment Share on other sites More sharing options...
Kbird1 Posted March 10, 2022 Share Posted March 10, 2022 3 hours ago, Ryan_McAllen said: I'll give this a shot. Guess I better find some 3D trees. Thank you for your time and assistance. This is very much appreciated! Sounds like you haven't downloaded ALL of Chief's (Free) Libraries yet...... https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/795 Full X13 Library Mick. Link to comment Share on other sites More sharing options...
