Chris_27 Posted February 26, 2022 Share Posted February 26, 2022 Good day everyone. im a new user of Chief Architect. I would like to ask your opinion. How do you design the garage floor? Because im having a problem how to level the Garage door to the driveway level without affecting the wall foundation and the floor inside. Thank you to all those who will answer. Link to comment Share on other sites More sharing options...
ericepv Posted February 26, 2022 Share Posted February 26, 2022 In the 'Terrain Specifications' DBX, adjust 'Subfloor Height Above Terrain' (in the 'General' tab). Set it to the level of your garage floor (probably -12 to -18"). Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2022 Share Posted February 26, 2022 The Terrain appears correct to me, looking at the Deck to the right , I am guessing there is 2-3 steps down into the garage from the house in which case you need to open the Garage Room Specs. and set the garage Floor to -14" ( 2 steps) or -21" (3 x 7" steps ) approximately depending on Riser Heights, then open the Garage door in 3D and raise/lower the Terrain as Eric mentioned so the driveway is just below the Garage slab. ( opening door makes it easier to see adjustments) M. Link to comment Share on other sites More sharing options...
