MTL-Homes Posted February 19, 2022 Share Posted February 19, 2022 Tried everything I can to get the wall intersections to look right with the "edit wall layers intersections" tool but really haven't had much luck. In General wall intersections look right till you have more than one wall intersecting at the same point. Thoughts anyone ? Wall Intersection 2.pdf Wall Intersection 1.pdf Link to comment Share on other sites More sharing options...
MTL-Homes Posted February 19, 2022 Author Share Posted February 19, 2022 Actually discovered that be redefining wall types to include all layers in Main Layer the intersections look better and the "edit wall layers intersections" tool seem to be more functional. I'm guessing there will be some unwanted side effects. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 19, 2022 Share Posted February 19, 2022 Something looks a lot more wrong than just wall connection issue. Post the plan so someone smart can help. I’m also curious about your suggestion regarding putting all layers on main layer. Can’t be a good idea. But if it is then I’d like to know as well. Link to comment Share on other sites More sharing options...
MTL-Homes Posted February 19, 2022 Author Share Posted February 19, 2022 So, yeah there are definitely issues with moving all wall layers into the main layer section, IOt does make wall intersections look better but creates dimensioning and platform issues. Here's .jpgs Link to comment Share on other sites More sharing options...
MTL-Homes Posted February 19, 2022 Author Share Posted February 19, 2022 Actually think it may have to do with "Partition Wall" check box in Define wall specification dialogue. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2022 Share Posted February 20, 2022 20 hours ago, MTL-Homes said: Actually think it may have to do with "Partition Wall" check box in Define wall specification dialogue. Best Practices...... Partition wall being checked should not be used in most conditions , Chief's Walls normally join on their Center Line, and this setting tries to stop that happening with the wall "touching" the other wall's surface only. Link to comment Share on other sites More sharing options...
MTL-Homes Posted February 21, 2022 Author Share Posted February 21, 2022 Thanks for explaining that Kbird1 Link to comment Share on other sites More sharing options...
