mtldesigns Posted February 13, 2022 Share Posted February 13, 2022 Working a small addition above a carport to a small bungalow. The deck that will connect to stairs is causing me fits. Don't know why either. I've done a hundred of these things, but this is the first time the railing goes all the way through the exterior wall. Any ideas on how to correct? Side note, I am trying to attach plan but its says its too big.. ?? Even compressed and zipped. Nothing to this model either, since its a addon, just the shell of the existing house. Is there a step I am missing to reduce the size? No furniture, plants, fixtures so scratching my head on this. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 13, 2022 Author Share Posted February 13, 2022 got it.. a dumb cupola was taking a big chuck of the size. go figure! 951192931_RAILINGISSUE.plan Link to comment Share on other sites More sharing options...
mtldesigns Posted February 13, 2022 Author Share Posted February 13, 2022 follow up, still a issue, but getting worse. As I move the railing out to adjust for size.. the hole gets bigger. Link to comment Share on other sites More sharing options...
Solution Mark3D Posted February 13, 2022 Solution Share Posted February 13, 2022 to start with the deck has negative ceiling height check that try that but there is still some other problem 1 Link to comment Share on other sites More sharing options...
Mark3D Posted February 13, 2022 Share Posted February 13, 2022 check second floor defaults ceiling heights the have negative height Link to comment Share on other sites More sharing options...
Mark3D Posted February 13, 2022 Share Posted February 13, 2022 plan attached should be fixed 951192931_RAILINGISSUE.plan Link to comment Share on other sites More sharing options...
mtldesigns Posted February 13, 2022 Author Share Posted February 13, 2022 19 minutes ago, Mark3D said: deck has negative ceiling height Sometimes its the obvious things.. geez! Thanks Mark. That second floor was added after the fact.. so I must have missed something Link to comment Share on other sites More sharing options...
