Billda Posted February 11, 2022 Share Posted February 11, 2022 Hi All, I run Chief Architect X13 on a: Razer Blade 15 Advanced RTX 3070 Gaming Laptop 360hz 15.6" FHD ,Intel i7-10875H 16GB RAM, Nvidia GeForce RTX 3070 8GB, 1TB NVMe SSD, RGB, AX WiFi + Bluetooth, Win10, VR Ready When I use the 3D camera for longer than 30 seconds, X13 crashes with no warning and then displays the attached message. Has anyone else experienced this, if so what was the solution? Thanks in advanced , Bill Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 12, 2022 Share Posted February 12, 2022 you can download a hot fix from NVidia 511-72, that should fix it. remember it a hot fix not the usual driver. if you search here you will find the link from kbird. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2022 Share Posted February 12, 2022 A long known Issue , some are having luck with Nvidia Latest Drivers...... Link to comment Share on other sites More sharing options...
