Cut angle on framing member
SDeckB
There are a series of tools on your active toolbar that will work for that sort of operation depending on the exact situation. For that particular problem you posted I would likely use the "Extend" tool.  The "Trim" or "Mitre" and "Lap" tools can also be quite handy as well.
Keep in mind that not all trim / extend functions work the same. Using a CAD line versus another framing member to perform the trim / extend operation will give you different results. Some will generate a bevel, while others will keep a square cut.
To miter two pieces, make sure they are short from the connection before using the miter tool.
