Molding on Interior Railing Walls
joestilwell95
I am trying to use a wall to create a structural beam in a room. The rail is defined as Post to Beam, no rail, and no posts. I end up with a free spanning beam. Is there a way to get that "wall" to follow the defaults for Room Molding? Or do I need to create molding polylines?
Thanks - Joe
You could also "old-school" it with a cabinet soffit.  You can put custom moldings on soffits but if the soffit is against the ceiling, the room molding might just wrap around it.
You can also convert your room molding into a custom molding polyline so that you can edit the shape to be whatever you want.
