bdillard Posted January 26, 2022 Share Posted January 26, 2022 Hello, I'm sure it is obvious but I've watched two videos and frankly it completely escapes me. I don't wan the step from my garage to my house to be 12" (approximately). I could put in another step but I'd rather raise the floor about 4". I tried messing around with a bunch of these but I might be in the wrong place as none of them seemed to fix it. I figure it was floor below for sure or stem wall but it doesn't seem to change it in the render. Link to comment Share on other sites More sharing options...
Solution SHCanada2 Posted January 26, 2022 Solution Share Posted January 26, 2022 did you try changing the absolute elevation of the floor? 1 Link to comment Share on other sites More sharing options...
bdillard Posted January 26, 2022 Author Share Posted January 26, 2022 Thanks! You may be 100% right but I'm not seeing it on that page - how do I get to absolute elevation for a room? Is that by adding a few inches to the floor entry and decreasing the same amount in the ceiling? Link to comment Share on other sites More sharing options...
SH_Canada Posted January 26, 2022 Share Posted January 26, 2022 you have it at 0 in the screenshot so add a few inches to that, and if you want, adjust the ceiling as well 1 Link to comment Share on other sites More sharing options...
SH_Canada Posted January 26, 2022 Share Posted January 26, 2022 btw make sure the garage room type is set to garage. It is odd your garage floor is at 0", and is below your main floor. normally the top of main floor floor structure is at 0", which should put your garage at -12 Link to comment Share on other sites More sharing options...
bdillard Posted January 26, 2022 Author Share Posted January 26, 2022 Thanks for all your help. It is set for garage. I do have bit of a glitch - I did something wrong and just a smidge of the wall is too high and sticking through the roof. I tried adjust a few heights but it seems to make the guttters much lower if I do that. Roof shot Attic view of the section that sticks through. Link to comment Share on other sites More sharing options...
bdillard Posted January 26, 2022 Author Share Posted January 26, 2022 My bad - changed it to a shelf ceiling and all is good. Thanks again for all the help! Link to comment Share on other sites More sharing options...
