RichardIdels Posted January 19, 2022 Share Posted January 19, 2022 In Chief Architect x12 I want to show alternate interior layouts for the same floor. Or show a drawing of the existng floor layout and another drawing of the proposed layout. So the owner can see on one screen how the new is changed from the existing. Link to comment Share on other sites More sharing options...
RichardIdels Posted January 19, 2022 Author Share Posted January 19, 2022 one of the main reasons I bought this program is to first draw a layer of the existing interior walls and a layer or many layers of design options for renovation on that same floor. all the while being able to see together how the renovations are different from the existing. Of course I can use the referance layer but I don't see a way to do alternate layouts of the same floor? HELP!! Link to comment Share on other sites More sharing options...
Dermot Posted January 19, 2022 Share Posted January 19, 2022 One way of doing this is by drawing the existing floor plan and then doing a "save as" on the plan. You can then use the reference display to display the existing plan below the proposed plan. Another way of doing this is to create a cad detail of the existing plan view and then convert it into a cad block that you can display before the proposed changes. We also have a number of remodeling training videos that you might want to take a look at: https://www.chiefarchitect.com/videos/playlists/120/remodeling.html 1 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted January 19, 2022 Share Posted January 19, 2022 Unless the client is totally tuned, spatially, and can imagine each of the options in 3D, why do this in 2D floor plan? I think your need is best served by 3D, and so take the time to show the client how to use the 3D viewer and walk through the spaces. Two plan files, A and B, and each in the Chief 3D Viewer Cloud. If you have already done a B after an A, you are just a few clicks away. Link to comment Share on other sites More sharing options...
RichardIdels Posted January 19, 2022 Author Share Posted January 19, 2022 Thank you every one for the advice! I just started using X12 today. I upgraded from years of using Home Designer Pro. Because graphic cards, in Canada, are extremely expensive, I am using x12 allowing the 3d features to run on my computers Link to comment Share on other sites More sharing options...
