Adesignpro Posted January 14, 2022 Share Posted January 14, 2022 I have tried just about everything to make a winder staircase. In my attached image, the landing function won't make this for me or I just don't see how to do it unless I can add a handle to a landing section. Not sure why this can't be another type of landing piece added to the stair tool palette. Tutorials mention a break tool that I don't find and it isn't "wall break". Please advise. Thanks. Link to comment Share on other sites More sharing options...
Dermot Posted January 14, 2022 Share Posted January 14, 2022 I would use 3 separate landings for this. Landings can be made any shape you want just like any other "polyline" shaped object. This tech article may also have some helpful info: https://www.chiefarchitect.com/support/article/KB-00884/creating-winder-stairs.html Link to comment Share on other sites More sharing options...
robdyck Posted January 14, 2022 Share Posted January 14, 2022 30 degree winders can be fairly simple... once you know how! You will nee walls on both sides of the stairs and you will need some CAD reference objects to help with snapping along with some CAD reference lines that layout the accurate start and stop lines of the upper and lower sets. Once these are in place, begin by drawing and placing the upper and lower sets. Then, draw the middle sat at a 45 degree angle, ensure it is fully within the inner and outer walls, then change it to a curved set use the 'Change to Line / Arc' tool. Check 'winders' on the middle set and fiddle around with the snapping. It will take math, some accuracy and a lot of practice! Link to comment Share on other sites More sharing options...
