Foundation bolt calculation
KingsOwn
I think you will need to write your own macro based on the length of the foundation wall.
Chief seems to use "=num_foundation_bolts"  but it seems that is an inaccessible global that if you are not happy with you can't change.
9 hours ago, KingsOwn said:
Does anyone know how to change the formula for how CA calculates the number of foundation bolts?
Just insert a different formula in your Foundation Wall or Slab Footing Wall Defaults.  Instead of "=num_foundation_bolts" for example, you could use something like:
=num_foundation bolts*2
=num_foundation_bolts/2
=num_foundation_bolts*0.75
=num_foundation_bolts+2
Or, to meet code where we do most of our building, something like this maybe...
=((length.to_ft-2)/4)+1
