ACADuser Posted January 7, 2022 Share Posted January 7, 2022 I added parapet walls on the Attic floor & this morning I noticed notches after I adjusted the entry room walls. Don't think that is what caused it but I can't figure why the entry room is causing this. Also there is an off wall cap bugging me. Any advice will be welcomed. Shields New.zip Link to comment Share on other sites More sharing options...
SH_Canada Posted January 7, 2022 Share Posted January 7, 2022 if I move the wall to be shorter ands then back again, it loses the floating piece, but also leaves it extended over the wall viewer shows if i delete the perpendicular attic wall it goes back to what you had and the floating piece i think the cap is trying to cover the attic wall. if I move the main wall away from the attic wall. it shows correct(ish). had to adjust the roof plane as well but probably not what you want Link to comment Share on other sites More sharing options...
ACADuser Posted January 7, 2022 Author Share Posted January 7, 2022 Thanks for looking at this. I just sent to tech support. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 7, 2022 Share Posted January 7, 2022 btw there was some small facia piece at the intersection, not sure if it was there on purpose. saw it with all layers on Link to comment Share on other sites More sharing options...
ACADuser Posted January 14, 2022 Author Share Posted January 14, 2022 From tech support: The reason for the jog in parapet walls on those two sides above the entry is because the entry room is marked to have a flat ceiling over it and so that adds structure to the height of that room, whereas the adjoining rooms don’t have that ceiling structure. A quick solution would be to open the room specification, go to the structure panel, and uncheck the box for flat ceiling over this room. Then use the ceiling plane tool in the roof tools to manually draw in a ceiling plane. Link to comment Share on other sites More sharing options...
