DIYJon Posted January 4, 2022 Share Posted January 4, 2022 As you can see, I have a rope light under a custom counter top which bleeds through the bottom of where the counter top meets the floor as well as up through where sink is. On the cabinet images, I have a few spots pointing down that bleed through to the hallway behind it. The only thing I can think of for the hallway is that I'm using a pony wall to create an F channel reveal to a flush baseboard, but other than that, I would think this should all work without having this strange bleed over. This isn't the only place this happens and I've been toying with light settings for quite a while now to try to get it right. Additionally, the way the lights display in the view seems to be erratic, going from dim at one point to blinding wash-out at other times without making any changes to the actual light settings. Any insight would be appreciated. Thanks! 2 Link to comment Share on other sites More sharing options...
stephenbc Posted January 16, 2022 Share Posted January 16, 2022 I find that depending on the light you use, sometimes if the 'spot' is selected and the direction of the light isn't straight down (as in the dialogue box below), light can travel through walls and even floors. 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted February 22, 2022 Share Posted February 22, 2022 I have that problem in a number of ways as well - some of the doors with panes in them have some panes lit from the other side for some reason. Link to comment Share on other sites More sharing options...
Dermot Posted February 22, 2022 Share Posted February 22, 2022 Some possible reasons: - You have shadows turned off. - You have a light source that is pointing the wrong direction. - You have an added light in your plan that you forgot about. - You are using a symbol with bad surface normals. - You have found a bug in the program that we are not aware of. Without a plan, people can only make random guesses. You should either post a plan or contact tech support. 2 Link to comment Share on other sites More sharing options...
caf200 Posted February 24, 2022 Share Posted February 24, 2022 On 1/16/2022 at 1:32 AM, stephenbc said: I find that depending on the light you use, sometimes if the 'spot' is selected and the direction of the light isn't straight down (as in the dialogue box below), light can travel through walls and even floors. Perhaps this user stretched or change the size of a light they put in. That "show position in camera view" is excellent for several things. If you change the size of a light the x-y-z coordinates of the light source still comes from the *original* location in the light fixture. Seems like an obvious bug and CA should adjust the Y coordinate to be relative to the size change. Link to comment Share on other sites More sharing options...
