KyleJantz Posted December 17, 2021 Share Posted December 17, 2021 Anyone else have this problem? If you click on it a couple times then it will resize to fit the 3D Elevations. After you click on a couple different pages and come back it looks like this again? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 17, 2021 Share Posted December 17, 2021 Wow that sure is interesting. You may be able to heal it by CTRL + X and then CTRL + ALT + V but have not tried it. Works for some other different types of issues. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 18, 2021 Share Posted December 18, 2021 1 hour ago, KyleJantz said: Anyone else have this problem? If you click on it a couple times then it will resize to fit the 3D Elevations. After you click on a couple different pages and come back it looks like this again? Are you using the Plan Scale Checkbox for 3D Images? M. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 18, 2021 Share Posted December 18, 2021 Regardless of whether or not it can be fixed that should be sent in to tech support as the images should not be larger than the row dividers ever. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 18, 2021 Share Posted December 18, 2021 10 hours ago, Chopsaw said: Regardless of whether or not it can be fixed that should be sent in to tech support as the images should not be larger than the row dividers ever. Yes I agree that is weird for sure.... Link to comment Share on other sites More sharing options...
