Edit & Status Toolbars Missing
gregtvillage
4 minutes ago, gregtvillage said:
I toggled the status bar but it doesn't appear. I think if I get the status bar back the edit toolbar will appear when its suppose to.
Be sure there is a little check box in the corner of the status bar toggle.
May not be a Chief setting at all.  It may just be that your window needs to be "Maximized" up at the top right.
The status bar can be turned on/off in your preferences.
I don't think there is a way to turn off the edit toolbar but it might not be visible on the screen.
Try using the Reset Options in your preferences to see if you can bring them back.
If all else fails, then you should try contacting tech support.
