Best place to learn building code?
ChiefUserKris2
25 minutes ago, Richard_Morrison said:
People here seem to have glossed over that you are asking about Code as related to Interior Design. You will get better answers if you are clear about the type of work you plan to do. There is only a small subset of the Code related to interior design, and it is unlikely that zoning ordinances are going to play a big part in your future.
Wow Richard, you make a very good point!  Yup, minimum room sizes, joist and beam spans, door and hall sizes, stair data, and windows parameters.  There is more but the list gets smaller.
I suggest that anybody using any code invest the time in organizing it by bookmarking and annotating the most used sections. I did it on the fly a little at a time as I applied a section to a project so it was not a show-stopper. Then I use the previous code to organize the next. (Actually I usually use the previous code and check the latest code for changes, then update every other issue.)
