McCallOfTheWild Posted December 10, 2021 Share Posted December 10, 2021 Looking for help to see if it's possible to add a door to a screen porch railing wall without the posts moving. Obviously there has to be posts for the added door, but is there a way to keep the other posts on the railing wall from auto moving? I've ticked "retain wall framing", but does nothing, and the posts relocate themselves. How do I stop the posts from moving? Attached is the problem I'm having. The lower railing wall posts were aligned under the "attic wall" posts, but when I added the door, the lower railing wall posts moved. Link to comment Share on other sites More sharing options...
rgardner Posted December 10, 2021 Share Posted December 10, 2021 This has been discussed quite at length on many occasions so a search for this information would be very helpful for you. https://chieftalk.chiefarchitect.com/search/?q=railing wall posts&updated_after=any&sortby=relevancy&search_and_or=and Couple of quick helper tips: 1.) Try breaking the wall and seeing what happens to the posts 2.) Make it invisible and place your posts and beams manually with the framing tools to get precise locations, footings, precise labels, etc. Link to comment Share on other sites More sharing options...
tommy1 Posted December 10, 2021 Share Posted December 10, 2021 When I do the screened porches, I generally place the posts and beams manually so you can do what you want. It does however depend on how the porch looks. Doing it manually really doesn't take that long once you get the hang of it and makes it easy to dimension posts. Link to comment Share on other sites More sharing options...
McCallOfTheWild Posted December 10, 2021 Author Share Posted December 10, 2021 Thanks y'all! I ended up doing a mixture of Ryan and Erik's ideas, and it was pretty easy. In Floor plan of porch I drew a cad line through center of posts then used break tool on line, put the door in, and the posts stayed in place! Link to comment Share on other sites More sharing options...
