Chrisdutch89 Posted December 9, 2021 Share Posted December 9, 2021 Chrisdutch christopher.dougherty0@gmail.com I'm having an issue with my default settings for wall types. I'm attempting to create a new exterior wall but when I open the wall types dialogue box I don't see the drop-down box for the inserting of materials and layers below the exterior layers/main layers/interior layers. I can't insert materials (exterior siding, building paper, etc.) Can anyone give me some direction on this? Chris Dougherty, RA, AIATroubleshoot question - 12.9.21.planTroubleshoot question - 12.9.21.plan Troubleshoot question - 12.9.21.pdf Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 9, 2021 Share Posted December 9, 2021 Chris, You need to select a wall layer before the options to insert, move or delete will be available. Link to comment Share on other sites More sharing options...
Solution Dermot Posted December 9, 2021 Solution Share Posted December 9, 2021 The dialog box does not look normal in the picture you posted. Maybe this is a problem having to do with your screen resolution or maybe you resized something and got into this state. If the problem was the result of some manual changes you made, you could try going into your Preferences, and under the Reset Options, click on the Reset Dialog Sizes button. In any case, it looks like there is a scroll bar at the bottom of the dialog box. You should be able to use this scroll bar to see all of the controls. If all else fails, you might want to contact technical support for more help. Link to comment Share on other sites More sharing options...
