DrewFenton Posted November 28, 2021 Share Posted November 28, 2021 Hello all---is there any way to control the 'lites' in the bottom of a window so you can only have the center vertical lite? When I check off 'Lites in Bottom' in the attached dialogue box, it removes all lites. Other window types like Prairie result in the same thing. The 2nd attachment shows what I am trying to do (e.g. the red vertical line). Link to comment Share on other sites More sharing options...
joey_martin Posted November 28, 2021 Share Posted November 28, 2021 You will need a custom muntin for that. easy to make. Link to comment Share on other sites More sharing options...
Dermot Posted November 29, 2021 Share Posted November 29, 2021 Depending on the size of the components, "Auto Adjust Lites for Component Size" may do what you want. If not, then custom muntins is the way to go. Link to comment Share on other sites More sharing options...
