How To Model Deck Railing Hung To Deck Edge?
GeneDavis
Need to model a deck railing that is built so 2x2 balusters mount against deck edge.
The 2x2s go down and have bottom ends 2 inches below tops of rims and are screwed to rims, thus the whole railing is offset out from the "deck room" edge.
I can model this affair using solids but was hoping there might be a way to spec it so Chief builds it.
did you see this thread from a couple of weeks ago ?  Glenn also came up with another method earlier in the year when I posed this question too
https://chieftalk.chiefarchitect.com/index.php?/topic/3192-railings-attached-to-rim-on-outside/
Glenn also came up with another method earlier in the year when I posed this question too though neither is "automatic"
https://chieftalk.chiefarchitect.com/index.php?/topic/1199-deck-post-fascia-mount-possible/?hl=%2Bfascia+%2Bmounted%26%2339%3B#entry9527
