GeneDavis Posted December 26, 2014 Share Posted December 26, 2014 Need to model a deck railing that is built so 2x2 balusters mount against deck edge. The 2x2s go down and have bottom ends 2 inches below tops of rims and are screwed to rims, thus the whole railing is offset out from the "deck room" edge. I can model this affair using solids but was hoping there might be a way to spec it so Chief builds it. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 26, 2014 Share Posted December 26, 2014 did you see this thread from a couple of weeks ago ? Glenn also came up with another method earlier in the year when I posed this question too https://chieftalk.chiefarchitect.com/index.php?/topic/3192-railings-attached-to-rim-on-outside/ Glenn also came up with another method earlier in the year when I posed this question too though neither is "automatic" https://chieftalk.chiefarchitect.com/index.php?/topic/1199-deck-post-fascia-mount-possible/?hl=%2Bfascia+%2Bmounted%26%2339%3B#entry9527 Link to comment Share on other sites More sharing options...
