Can Construction Lines be centered to a Masonry Wall?
JuanR2
Go to solution Solved by glennw,
  On 11/15/2021 at 9:32 PM, JuanR2 said:
When I center the Construction Line to a Wall, it centers to the middle of the complete assembly (Masonry Wall + Continuous Insullation), instead I need to center it to the Main Layer (Masonry Wall)
Expand
Then you should move it to the center of the main layer. You probably know the main layer thickness. Move the line to the edge, then replicate it over half that amount.
  • Solution
Or...you can do it without knowing the main layer thickness..
Select the construction line.
On the edit Toolbar click on "Click On This And Then On An Object To Center The Selection On An Object".
On the edit toolbar click on "Click On This And Then On Two Locations To Center This Object Between".
Snap Point A to one side of the main layer and Point B to the other side of the main layer.
Click on the screen to finish.
Expand
Yessss!!! It works fine!!!! (spent all morning reading the manual).
