ClearDrafting Posted November 15, 2021 Share Posted November 15, 2021 Whenever I draw a brick wall now on the foundation wall below it it shows this odd line in the 'Slabs" layer under the brick veneer. How do I get rid of it while still showing the "Slabs" layer? Thank you in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 15, 2021 Share Posted November 15, 2021 That "line" is the line of the "Brick or Masonry" ledge and should not be "removed" no matter what you think. It IS physically there in fact as well as in the plan file and should not be removed showing then NO brick ledge. DJP 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2021 Share Posted November 15, 2021 David is right it is the Brick Ledge , do a Floor Overview Camera while on level 0 and you should be able to see it. M. 1 Link to comment Share on other sites More sharing options...
