Doug_N Posted November 10, 2021 Share Posted November 10, 2021 (edited) I am working on a new build cottage and in this design, there are dormers that are misbehaving (or maybe I just don't know how to use this feature) in that the auto return doesn't seem to work right. Both of these dormers have the exact same dormer roof settings. The dormer on the left is moved 1' behind the plane of the exterior wall, and the one on the right has the front wall of the dormer in the same plane as the exterior wall below. The other thing is a gable roof over a sunroom has a strange artifact in the window cut out. The bottom of the window does is not correct. The area behind the window is an open to below area on the second floor. Anyone have any thoughts about this? I have sent this to tech support as well, because I suspect the dormer issue is a bug. Rice Lake Cottage.zip Edited November 10, 2021 by Doug_N Changed the included file to the correct version Link to comment Share on other sites More sharing options...
Doug_N Posted November 10, 2021 Author Share Posted November 10, 2021 Then there are the problems inside of the dormer. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 10, 2021 Share Posted November 10, 2021 Doug , you uploaded the wrong plan..... Link to comment Share on other sites More sharing options...
Doug_N Posted November 10, 2021 Author Share Posted November 10, 2021 Mick, Changed the included plan file. Thanks for pointing that out. Doug Link to comment Share on other sites More sharing options...
