Why Chief Architect Room Planner doesn't have a Default Room Wall Width?
stevebustamante
3 hours ago, stevebustamante said:
I wish Chief Architect Room Planner had a Default Room Wall Width. That way I wouldn't be changing room wall width each time I create a room. It is tiring.
I believe because the industry standard is to work with dimensions from the exterior of the house and if you resize your walls from say a 6" to a 4" stud wall it won't change the exterior it just pushes into the interior the 2" (sized about exterior layer.)
