Josh_Thiessen Posted November 4, 2021 Share Posted November 4, 2021 Hi, I'm having an issue on this plan, when I try to set the ceiling height in the entry to be the same as the rest of main floor (109 1/8") it automatically changes the garage ceiling height as well. I can't seem to "unlink" the two rooms... New Home.plan Link to comment Share on other sites More sharing options...
MPDesign Posted November 4, 2021 Share Posted November 4, 2021 Place a check mark beside the default ceiling height, then if you need it a different ceiling height use the shelf ceiling option Link to comment Share on other sites More sharing options...
robdyck Posted November 4, 2021 Share Posted November 4, 2021 8 hours ago, Josh_Thiessen said: I can't seem to "unlink" the two rooms... Your issue comes from the fact that your plan does not have the room shapes defined completely on both floors. You currently have overlapping rooms. The ceiling height in the entry cannot be higher than the floor above. So, define the rooms on the 2nd floor using walls, railings, or room dividers. Ensure alignment with the rooms and walls below. You will then be able to make the necessary adjustments. 2nd Floor: The landing portion needs to be separated from the area over the garage. Main Floor: the entry will need to be divided in line with the wall dividing the stairs to allow for separate ceiling heights. Link to comment Share on other sites More sharing options...
Josh_Thiessen Posted November 6, 2021 Author Share Posted November 6, 2021 Thanks a lot! That solved the issue. Much appreciated. Link to comment Share on other sites More sharing options...
