LED light symbol
DianeP
1 hour ago, DianeP said:
Hi All,  What are you doing for LED lights that have replaced the recess cans we used to use in houses.  Have you found a new symbol or is there a way to change the R to an L in the recess symbol in the library.  Thanks!
They are still Recessed Cans , it's just the Bulb is now LED , so whether you do that with Notes of make a change to the CAD Block is upto you,
this KB article should show you how to make it L not R if you want to
https://www.chiefarchitect.com/support/article/KB-00805/editing-2d-cad-blocks-assigned-to-3d-symbols.html
Thanks for the solution!
