How to get slab to show with stem wall foundation?
treboralmasy1
I am having difficulty getting the slab to show with the stem wall type foundation (second picture).
It looks okay if I turn on the display for 'Floor Surfaces' but that doesn't seem like what it should be doing.
I also noticed on the monolithic slab (last image) it does show the slab even without the 'floor surfaces' option selected.
You are using a camera view that the layer set has the floor surface turned off.  When you turn it on that is when you see it….  That is how layers work, they turn on and off what you want to see.  As far as the monolithic slab is concerned it is part of the foundation so is not a floor surface, again on a different layer.
Quick tip.  Learn to work with your Active Layer Display Options (commonly called ALDO) window open. Click on the item you are seeing and ALDO will show you all layers associated with that item.
