sclarke0 Posted October 25, 2021 Share Posted October 25, 2021 I have a tricky project where we have a u shaped winder staircase, but there is a new set of stairs (the bit with carpet) with sprawls off the corner of the main stairs creating almost T junction. The picture attached explain it. I am trying to figure out a way to make this safer, any ideas are welcome. Thanks a lot Stuart Link to comment Share on other sites More sharing options...
javatom Posted October 25, 2021 Share Posted October 25, 2021 Wow, that thing should be in the carpenter hack hall of fame. 1 Link to comment Share on other sites More sharing options...
SH_Canada Posted October 26, 2021 Share Posted October 26, 2021 if you have space at the bottom of the stairs and enough headroom(or make the headroom), you could: change the top winder to a landing. bring the bottom stairs straight out 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 26, 2021 Share Posted October 26, 2021 I would probably add an additional angled area to the top wider from the edge of the secondary stair to about 1/3 of the top winder. Maybe even radius that filler so that it's tangent to both. 1 Link to comment Share on other sites More sharing options...
