BeachHouse1 Posted October 21, 2021 Share Posted October 21, 2021 Hello Y'all The Rafter Spacing on the "Build Framing" Popup Form indicates 16" On Center. When the Build Roof Framing is initiated it creates Rafters 24" O.C. Anyone seen this or have a remedy? Thanks All Link to comment Share on other sites More sharing options...
MPDesign Posted October 21, 2021 Share Posted October 21, 2021 I would look in the roof dbx, in the structure tab. That is probably set to 24" Link to comment Share on other sites More sharing options...
BeachHouse1 Posted October 21, 2021 Author Share Posted October 21, 2021 19 minutes ago, MPDesign said: I would look in the roof dbx, in the structure tab. That is probably set to 24" It has the same information as the Roof Framing Dialog. They both say 16" O.C. Link to comment Share on other sites More sharing options...
Dermot Posted October 21, 2021 Share Posted October 21, 2021 When you open the Roof Plane Specification dialog, what does it say on the structure panel? The reason this is important is that each roof plane can have separate framing settings. When ever you build a new roof plane, it will use defaults. If you modify your defaults later, existing roof planes will not change dynamically like some other objects (like cabinets, doors, or windows can). If this spacing is correct in the Roof Plane Specification dialog, then the problem may be that you have not actually rebuilt the framing. Try rebuilding the framing manually for one of your roof planes to see if it is then correct. Link to comment Share on other sites More sharing options...
