jp26jp Posted October 17, 2021 Share Posted October 17, 2021 I have 3 gable roofs that are side by side but the middle one needs to sit on top of the 2 on the outside. I cannot figure out how to do this. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 17, 2021 Share Posted October 17, 2021 Take a look carefully at the information resident on your Build Roof Tab - Roof Styles Tab where it explains how to preprogram walls for building auto roofs, follow the instructions found there and you will be fine. DJP Link to comment Share on other sites More sharing options...
jp26jp Posted October 17, 2021 Author Share Posted October 17, 2021 Because of the difference in the height of the roof on the left and the right I'm not able to utilize the auto roof feature with 3 gable roofs. How would I do this manually? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 17, 2021 Share Posted October 17, 2021 On 10/17/2021 at 7:32 PM, jp26jp said: sit on top of the 2 on the outside. I cannot figure out how to do this Expand Raise the Ceiling Hgt of the middle room and Auto Roof should do it for you... once Auto is Off it will stay there even if you lower ceiling again. Or Raise them up using Transform/Replicate , using a (positive number for up) Move>Z Delta M. 1 Link to comment Share on other sites More sharing options...
