Chiefuserodd Posted October 15, 2021 Share Posted October 15, 2021 Hey Mr. Chief Wizard, Is there a way to display only selected text in say a "Framing, Floor Plan View" active layer set that will not show up in the "Working Plan View"? When I send to Layout, I would like specific text associated with the "Framing, Floor Plan View" to only show up on the "Framing" page and not on the regular plan view sheet that I have. Thanks, T Link to comment Share on other sites More sharing options...
javatom Posted October 15, 2021 Share Posted October 15, 2021 Place your text in a layer that will be used with the floor plan view. Turn that layer off in the other views. Each view should have its own text layer set that is special to that view. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 15, 2021 Share Posted October 15, 2021 The answer may depend on what Version of Chief or Home Designer Product you are using, but if you are in the correct Saved Plan View , the Text should go to it's dedicated Layer eg. Text, Framing. then make sure that layer is no on in Working Plan view This is how to do your Signature. 1 Link to comment Share on other sites More sharing options...
Chiefuserodd Posted October 15, 2021 Author Share Posted October 15, 2021 Thank you both for your help. I'll give that a try. It sounds as you both are saying the same thing. Cheers and have a good weekend. Link to comment Share on other sites More sharing options...
Chiefuserodd Posted October 15, 2021 Author Share Posted October 15, 2021 Thanks also, David, for the instructional on how to do the signature. I'll resist the temptation to do it right now and finish my drawings first. I must say my ADHD wants to kick in to distract me from the work at hand. Cheers Link to comment Share on other sites More sharing options...
