Topo information to create a terrain
Doug_N
11 minutes ago, Doug_N said:
50 minutes ago, Chopsaw said:
Doug that should import ok if you dump the Description column.  Maybe do that in excel first.
I will give that a shot!
Sorry it looks like chief will import a Description...
Just not sure if the data is workable or not.
2 hours ago, Doug_N said:
The plan file is my imported and adjusted terrain
That looks better than mine.  Maybe only three or four more points to sort out that do not belong ?
It may help to connect the SIB's with plot lines to keep you oriented.
Did you import as # X Y Z  Description  (comma delimited)  and Metric ?
4 minutes ago, Doug_N said:
Hi Chopsaw,
Yes that is exactly what I did.   Maybe I should limit the terrain to the SIB values for X and Y
Maybe find 4 or 8 SIB's and see if you can connect them to look anything like the PDF Site Plan.
I think # Y X Z  Description  (comma delimited)  gives you the correct orientation.
Any Idea what the UGV is at the NE corner because that may explain the missing SIB ?
"Under Ground Vault" perhaps ?
