junior Posted October 7, 2021 Share Posted October 7, 2021 Using X12 My exterior walls show only the stud wall lines with the fill color. How can I get the osb, siding, and drywall lines to show in the plan view. Also, my interior walls do not show the drywall lines. Link to comment Share on other sites More sharing options...
javatom Posted October 7, 2021 Share Posted October 7, 2021 Go into your layers and turn off "walls, Main layer only". 1 Link to comment Share on other sites More sharing options...
junior Posted October 8, 2021 Author Share Posted October 8, 2021 Thank you, problem solved. Link to comment Share on other sites More sharing options...
rgardner Posted October 8, 2021 Share Posted October 8, 2021 1 hour ago, junior said: Thank you, problem solved. It is very much appreciated and helpful to the forum that when someone fixes the problem they had that they share the reason they had the issue. So when others SEARCH the forum they can usually find the answer to their issue. Helps repetitive questions from being asked and helps the user find the answer quicker. A little way of giving back to the community. One new way that was recently setup to answer it is to mark the proper answer as solved/solution. Link to comment Share on other sites More sharing options...
