ForinoCo Posted September 30, 2021 Share Posted September 30, 2021 Hi Everyone, We are drawing a townhome building, and they asked us to show the 1ft "jump' between the units that will reflect the garage floor level changing, which then affects the floor/ceiling heights of the whole unit due to grading. Attached is the print of the building as it sits now. From left to right, they need the building elevations shown with the left 2 units being 1ft lower than the other 4 units in the building. I'm pretty confident it would be a change to the ceiling height of each floor, but with the walls already creating so many different rooms is there an easier way to change the ceiling height of an entire floor versus going room by room on that level of the house for those 2 units to drop them down 12"? TSM_15_20 Chestnut_LH_3BR.pdf Link to comment Share on other sites More sharing options...
MarkMc Posted September 30, 2021 Share Posted September 30, 2021 If you are using X13 you can use the object eyedropper on rooms now. Do one room on first floor, object eyedropper, click other rooms, then go to second floor. Pretty quick. Link to comment Share on other sites More sharing options...
robdyck Posted September 30, 2021 Share Posted September 30, 2021 You can group select all the needed rooms to make the change (-12"). And of course, you'll need to adjust the roof as well. I'd do that by making a copy using the transform / replicate tool to make a copy 12" lower in the 'z' axis. Then, drag the roof plane side for length adjustments. Link to comment Share on other sites More sharing options...
ForinoCo Posted September 30, 2021 Author Share Posted September 30, 2021 Thank you so much for the insight, I never even gave those a thought for this type of application. I will give them a shot! Link to comment Share on other sites More sharing options...
