Wall Bridging default thickness
Norm4Man
Thanks I am trying to find an older tutorial that may show it? I may be very well mistaken but will add this as a request in the next update, it would save me a lot of time with manual framing edits
I don't remember it myself, and thought it used the same thickness as specified for the Stud or Plate by default
* see below , appears to be hard-coded at 38mm
Setup the framing in your Template Plan to use 45mm and you won't need to do it again.
I am not 100% sure why Chief's Templates have always set the default to 38mm in the Metric Templates, apparently nobody checked real world specs,
(direct conversion from 1 1/2" I think) thus I have always done the above each version.
