RicatRandM Posted August 12, 2021 Share Posted August 12, 2021 Greetings, I'm trying to put recessed lights in a sloped ceiling. Pitch is a 6/12. Can't seem to get the light adjusted to point straight down onto a countertop? Tried using the eyeballs... Any suggestions? Ric Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2021 Share Posted August 12, 2021 Turn R.Can light off and use an Added 3D Light perhaps? M. Link to comment Share on other sites More sharing options...
Dermot Posted August 12, 2021 Share Posted August 12, 2021 The recessed lights should be pointing down by default, even when the fixture is being rotated to mount flush on a sloped ceiling. The actual direction the light is pointing is controlled by the Tilt Angle and the Direction Angle. Turning on Show Position in Camera view will give you a nice little indicator showing you where the light is actually pointing. If you are sure the light is pointing where you want and you still don't see the light in your camera view, then the problem could be something completely different, like the light is not actually on or it is not actually located where you think it should be. At any rate, if you need more help you should probably post a plan. If you think you have found a bug, you should contact tech support. Link to comment Share on other sites More sharing options...
