mholzdesign Posted August 10, 2021 Share Posted August 10, 2021 Hi - I would like to know how to copy all electrical components from one plan to another (I have a macbook pro). I used to click on an electrical item, go to marquee select, highlight the plan, copy, and option/command/V in the new plant to paste. With the latest version I can't seem to locate the marquee select icon. Thank you for your help! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 10, 2021 Share Posted August 10, 2021 1 hour ago, mholzdesign said: Hi - I would like to know how to copy all electrical components from one plan to another (I have a macbook pro). I used to click on an electrical item, go to marquee select, highlight the plan, copy, and option/command/V in the new plant to paste. With the latest version I can't seem to locate the marquee select icon. Thank you for your help! Since you havn't done your Sig yet ( a good idea ) I'll assume X13 in use.... Link to comment Share on other sites More sharing options...
mholzdesign Posted September 10, 2021 Author Share Posted September 10, 2021 Thank you for your response. I have now noted X13 in my signature as well so thank you for the heads up. Link to comment Share on other sites More sharing options...
rgardner Posted September 10, 2021 Share Posted September 10, 2021 On 8/10/2021 at 11:30 AM, mholzdesign said: Hi - I would like to know how to copy all electrical components from one plan to another (I have a macbook pro). I used to click on an electrical item, go to marquee select, highlight the plan, copy, and option/command/V in the new plant to paste. With the latest version I can't seem to locate the marquee select icon. Thank you for your help! On 8/10/2021 at 12:58 PM, Kbird1 said: Just to note that it only shows up once you have something selected. Link to comment Share on other sites More sharing options...
