Looking for Steel Column Ideas?
ACADuser
This house has 2 spots that need columns that sit on a 10" wide concrete wall, (formed & poured)
The 6" square steel columns don't allow much room for the base flange bolts & still have 1.5" cover on the steel.
Looking at recessed bolts for this, see attached. But was looking for any other ideas you might have.
Not looking to go with wood as it is exposed to the weather. (Austin Texas)
That is a somewhat open hallway & open stair area.
One we have used here is to Drill the steel Post in both directions ( sized as needed ) , and insert pieces of rebar
 right through and weld them into the post, and crank as needed. Can be tied into Wall Rebar system too.
