Wynsong Posted August 2, 2021 Share Posted August 2, 2021 Where is the default setting for Terrain Elevation Data LABEL hidden? I want it in fractional inches, not fractional feet or mm!! I can't find it in the Default Settings so where is it. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 2, 2021 Share Posted August 2, 2021 Decimal Inches: Fractional Inches: No default setting that I am aware of unfortunately. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 2, 2021 Share Posted August 2, 2021 Topo Elevation Data is normally done in Decimal Feet to 2 decimal places , I am not sure why you are creating you own label though? CA should label it per the Elevation tab setting. (height) Do you have it setup to display in Decimal Feet? then set the Number style the same in the Elevation Data DBX ie Decimal feet bit more info on that part here : https://www.chiefarchitect.com/support/article/KB-00575/creating-a-plot-plan.html and perhaps this one : https://www.chiefarchitect.com/support/article/KB-00719/importing-terrain-elevation-data-from-a-dxf-or-dwg-file.html M. Link to comment Share on other sites More sharing options...
