Recessed windows and wall
40 minutes ago, capitaldesigns said:
These windows and 3" of wall around the windows are recessed into a 2x8
stud wall.
So the 2x4 or 2x6 wall cuts at one point and turns into a 2x8 wall then it cuts again and goes back to the other size?  Does that help you figure out how to do it?
Hint:
If it is 2x4 or 2x6 at the base then adjusts to a 2x8 wall a bit off the floor then you can use a pony wall and set it to be flush at interior.
    29829
    MeganB
    MeganB
