wncbw7 Posted July 21, 2021 Share Posted July 21, 2021 I have watched the video and read through the posts and cant find a way to keep the interior lights on while doing an exterior raytrace in X13. Had no problem in X10 with this. Help Link to comment Share on other sites More sharing options...
Adam_Gibson Posted July 21, 2021 Share Posted July 21, 2021 Has the "Maximum Allowed Lights" default changed since you upgraded? The default is 8, but can be changed to anything. It could be that they're on in parts of the plan that you can't see from where your camera is. Just a suggestion. I'm not looking at Chief to know where that setting is at the moment. Link to comment Share on other sites More sharing options...
wncbw7 Posted July 21, 2021 Author Share Posted July 21, 2021 Adam, I did change that setting to 200 so all of the lights would be on. they for some reason will be on if I toggle the sun, but when the sun is on the lights are off. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 21, 2021 Share Posted July 21, 2021 Once you have enabled a maximum of lights and have verified that they are "ON" then it is a matter of balancing the Sun light intensity against the visibility of the interior lights. This assumes that your video card can support that number of light sources simultaneously (not all video cards can do this but up to date ones should be able to). DJP Link to comment Share on other sites More sharing options...
Chiefer Posted August 25, 2021 Share Posted August 25, 2021 same problem here with lights not on during daytime (x13) any solution? Link to comment Share on other sites More sharing options...
