SidneyH Posted July 19, 2021 Share Posted July 19, 2021 Hi everyone, I'm trying to improve how my elevations are presenting in layout. I'd like to increase the line weight of the walls and roof while decreasing the pattern line weight that the siding and roof shingles creates. I have tried adjusting the plot lines as well as adjusting the lines weights in Layer Display Options. I would like my drawings to present like the example below including the shadowing. Any advice would be greatly appreciated. Thank you. -Reeves EXAMPLE MY EXISTING LAYOUT Link to comment Share on other sites More sharing options...
BhamArch Posted May 10, 2022 Share Posted May 10, 2022 Hi Sidney. I'm after the same goal. It doesn't look like anyone had suggestions. Did you ever figure out a way to get your elevation to look like your example? Dave Falk Dell G7 Chief X13 Link to comment Share on other sites More sharing options...
mtldesigns Posted May 10, 2022 Share Posted May 10, 2022 36 minutes ago, BhamArch said: Did you ever figure out a way to get your elevation to look like your example Gents, A couple thing you will need to do to get close to what you want as the example. To get the shadow, in your plan view pick the camera for the elevation view (don't open the view) and "Open Object". Check Show Shadows and Ray Casted Sun Shadows. OK. I always say no the "Cad Clip Lines" After that is set, open up the view to get the shadows you like. I saw a example on another Chief project where they put a date and time of the "sun shadow" on that view. It helps, because every time you may have to open, you will know how to make that setting. You can see it on the bottom corner of my attachment. Now that your view is loaded on the layout sheet, pick that view, as I show and open object. You will see a layout box specification. Play with the Edge Line and Pattern Line defaults to get what you like. To each his own. Hope this helps. I got a lot of tips by pulling up some Chief plans and surfing.. Also some guys and gals on here have some great advice.. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 10, 2022 Share Posted May 10, 2022 58 minutes ago, BhamArch said: Hi Sidney. I'm after the same goal. It doesn't look like anyone had suggestions. Did you ever figure out a way to get your elevation to look like your example? Dave Falk Dell G7 Chief X13 Send to Layout as PLOT Lines not live Cameras so you have full control of the Line Weights etc, had this problem today in a Client's plan with the B&B Siding not showing at all well in the elevations , change Pattern lines to a Darker Grey ( or Black ) and using Plots Lines fixed that issue and also lets the Layout look more like it will print , while you work.... *** if you change the Material definition for the Roof Shingles , they won't appear "black" in layout in Vector Views.... but will still look correct in 3D camera views Mick. Link to comment Share on other sites More sharing options...
