Billda Posted July 7, 2021 Share Posted July 7, 2021 Hi team, I've purchased a new laptop and successfully migrated my chief x12 on my old laptop to x13 on the new one. However, there a re few things not referenced correctly on the new laptop, specifically when navigating to the same dropbox folder (where I keep all of my plan files etc). e.g. Firstly, the referenced plan files: My old laptop had the filepath c:\Users\mais2\dropbox\etc etc for the plan file location When I load the plan im working on, there are some references to older plan files via the link above. However my directory for dropbox is C:\Users\Bill Moore\Dropbox\etc etc Instead of relinking these one by one - is there a quicker way to do this? Secondly, when I do relink to the new filepath as above, there are still some images like logos etc that arn't coming through. Again it seems to be an issue with the C:\Users\Bill mais2\dropbox versus C:\Users\Bill Moore\dropbox\etc I can't work out how to get these jpegs etc back into my plans. Can anyone please advise? Cheers, Bill Link to comment Share on other sites More sharing options...
lbuttery Posted July 7, 2021 Share Posted July 7, 2021 you should contact CA's tech support - they can best advise they open early when adding images to a plan or layout you can select the image and select "save in plan" then the plan can be moved anywhere and the images are always there I have been recommending that this be a preference item for over 15 years as I constantly get bit by this "foible" - so does my partner I try to remember to select "save in plan" for all images at the time I add them but invariably I miss some and then "CHOMP" sometime in the future Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted July 7, 2021 Share Posted July 7, 2021 Try putting the Logos in the X13 Textures Folder , it is one Place Chief Looks for missing images/textures if it can't find them in the Plan Folder or the library. Once working again open the Logos in Chief and make sure the "Save in Plan" Box is Checked so you can't lose them again Link to comment Share on other sites More sharing options...
Billda Posted August 11, 2021 Author Share Posted August 11, 2021 Thanks fellas. “Save in plan” works. It’s a bit slow having to go through the old x12 files checking the images before opening in x13. would be nice if it was in preferences Link to comment Share on other sites More sharing options...
