Failing to use wood tile filling
kintaro
Hi
I've spent many hours and keep failing. I'm trying to put a parquet floor, but instead of a standard tile structure it keeps making it as in the below picture
, whereas I want it to look as a "brick layout"
how I want it to look:
I tried to play with the patterns but to no avail. Even when I tried to use "courtyard" fill, it doesn't affect the layout (see below).
What am I doing wrong?
got it. It really sucks, especially when you want to play with different parquet materials and find out that you need to start drawing each and every one of them yourself and manipulating the material..
Thanks, it really helps (at least I know that it's not something I did wrong but that it's not possible that way)
This is not a parquet look.  Parquet is a pattern of 6 pieces of 1x6 or 8 pieces of 1x8 small wood pieces together in square blocks quarter turned each time.  What you are looking for is a large width plank pattern which is available in chiefs bonus catalogs under patterns.  image.jpeg.30777b52bbf6ba1d3be619a58fcacb1d.jpeg
