kintaro Posted July 4, 2021 Share Posted July 4, 2021 Hi I've spent many hours and keep failing. I'm trying to put a parquet floor, but instead of a standard tile structure it keeps making it as in the below picture , whereas I want it to look as a "brick layout" how I want it to look: I tried to play with the patterns but to no avail. Even when I tried to use "courtyard" fill, it doesn't affect the layout (see below). What am I doing wrong? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 4, 2021 Share Posted July 4, 2021 Patterns do NOT effect 3D Images , only the "Lines" seen in Vector Views. See if this Post in Tips helps you make a suitable 3D image..... Mick. Link to comment Share on other sites More sharing options...
kintaro Posted July 4, 2021 Author Share Posted July 4, 2021 got it. It really sucks, especially when you want to play with different parquet materials and find out that you need to start drawing each and every one of them yourself and manipulating the material.. Thanks, it really helps (at least I know that it's not something I did wrong but that it's not possible that way) 1 Link to comment Share on other sites More sharing options...
rgardner Posted July 4, 2021 Share Posted July 4, 2021 This is not a parquet look. Parquet is a pattern of 6 pieces of 1x6 or 8 pieces of 1x8 small wood pieces together in square blocks quarter turned each time. What you are looking for is a large width plank pattern which is available in chiefs bonus catalogs under patterns. 1 Link to comment Share on other sites More sharing options...
