Forestshepherd Posted June 21, 2021 Share Posted June 21, 2021 I have checked every wall on my structure and none of them have "No Room Definition" selected. All of my walls seem to be completely enclosed. My Room Layer Display is unlocked. Is there something else I should look into? As you can see in the screenshot, whenever I try to select a room, the Slab Specification window pops up. I am unable to select a room in any part of my structure. Hoping there is a simple fix for this! Thanks so much for any help you can offer! Link to comment Share on other sites More sharing options...
Chopsaw Posted June 21, 2021 Share Posted June 21, 2021 Will tab allow you to select the room after the slab is selected initially ? Link to comment Share on other sites More sharing options...
GeneDavis Posted June 22, 2021 Share Posted June 22, 2021 Maybe you should soak in some training: https://www.chiefarchitect.com/videos/watch/6022/foundation-slab-full-basement-crawl-space-dutch-cottage-design.html You model the building first, then Chief builds your monolithic thickened-edge slab foundation for you on level 0. Link to comment Share on other sites More sharing options...
