GeneDavis Posted June 21, 2021 Share Posted June 21, 2021 An upper wall between two spaces needs to be shaped so as to ride atop a carry beam, part of a timberframe bent. See the image. Here is the file. https://drive.google.com/file/d/1_m21MY0Num-MAuFgWjkOsx1WSRL2vwBd/view?usp=sharing I screwed up the model somehow. Unable to get the shaped wall with a visible wall, I did it as an invisible one, and put a p'solid in the space where needed. I would like to be able to do it with a visible wall. I drew a line around the area where I need some how-to advice. Link to comment Share on other sites More sharing options...
glennw Posted June 21, 2021 Share Posted June 21, 2021 Gene, If I am following you correctly... Is this what you mean? If so, you need to uncheck Invisible and No Room Definition for the selected wall - or pull the main wall through to replace the short piece of wall. And then for the room on level 2 above the lounge room, make it Open Below. Link to comment Share on other sites More sharing options...
GeneDavis Posted June 21, 2021 Author Share Posted June 21, 2021 Thanks, but no, that wall has to be "cut" by the ceiling plane in the kitchen-dining room, so that the result looks like my image. And it also needs a cut on its exterior side because above the roof, it gets siding, and below the roof, gets no siding. Link to comment Share on other sites More sharing options...
